electronic unit - NCRS Discussion Boards
electronic unit
  • Lyndon S.
    • April 30, 1988
    • 1027
    electronic unit
  • Ken A.
    • July 31, 1986
    • 929
    Re: electronic unit
    Put it back the way it was, you've wasted your money, unless you drive 30K miles a year.
    • Lyndon S.
      • April 30, 1988
      • 1027
      Re: electronic unit
      • Michael H.
        • January 29, 2008
        • 7477
        Re: electronic unit
        Originally posted by Lyndon Sharpton (12791)
        Did you reset the timing after you installed the new unit? Not likely it would be the same as it was before.
        • Ken A.
          • July 31, 1986
          • 929
          Re: electronic unit
          Then you need to get an old set of Delco points or Blue Streak & make sure you've got a good coil & the correct ballast resistor. They should last at least 2 years in a weekend driver.
          • Lyndon S.
            • April 30, 1988
            • 1027
            Re: electronic unit
            No I did not reset the timing, is that really necessary?
            • Michael H.
              • January 29, 2008
              • 7477
              Re: electronic unit
              Lyndon,
              If you replaced the ignition points with an electronic pickup, I would guess that the chances of getting the pickup to trigger the ignition in exactly the same place, in degrees, that the point set did, are near zero.
              Moving the pickup position would produce the same results as rotating the distributor housing which changes the ignition timing.
