I had to replace the original tach cable assembly on my 66 SB because the outer cable case started to separate at the cable to flange joint, due to the tight bend where the cable flange goes into the distributor. (This is a typical problem with C2 tach cables). The tach needle was fluttering and I suspected a cable problem. Sure enough, when I removed the inner cable from the casing I could feel resistance near the bend location and suspect that there is a kink inside the casing. I tested the tach by connecting a new repro cable assembly to the tach and turned the distributor end with a drill. No flutter occurred, confirming the problem was with the original cable.
Hope to see you in Michigan.
Dave K.
Dave K.
