My 89 front calipers both rattle when going over bumps. Not sure if it's the calipers or shields. Anyone else experience this noise and fix it lately....thanks.
89 front caliper rattle.
Tags: None
- Top
Re: 89 front caliper rattle.
Richard-----
There are several possibilities. First, there's the possibility of missing pin clips. These are GM #10132842, but they're discontinued.
Second, there's the possibility of worn pins. These are GM #10140586 but they're also discontinued.
Next, there's the possibility of worn caliper mounting brackets. These are GM #10181205, left, and 10181206, right. You guessed it; they're discontinued, too.
The above part numbers apply if you have JL9 brakes (standard). I don't think any 1989's were delivered with J55 HD brakes, but it's possible. You can easily tell by checking your "service parts identification label".
Although all the above parts are GM-discontinued, I think they are available from aftermarket sources like Vette Brakes, etc.In Appreciation of John Hinckley- Top
