I have some brackets and some other parts which I am not sure what type of finish the parts should have nor where these parts go. Which parts should be painted (black or color of the car), blackened or plated?
1.bolt.
2. The small screw is a crutch head.
3. BRAKE PEDAL PULL BACK SPRING PLATE. Paint black?
4. thin nut
Brackets (windshield)? Which ones should be plated or painted?
1. bracket -
2. bracket -
3. bracket -
4. bracket -
1. Lag bolt??
2. Two different screws with phillips heads.
3. oval spacer?
4. Brakes?
5.
6.
Someone else took these parts off. I have to identify the parts and try to get the correct paint or plating applied.
1.bolt.
4. thin nut
1. bracket -
2. bracket -
3. bracket -
4. bracket -
1. Lag bolt??
3. oval spacer?
4. Brakes?
5.
6.
