I need help identifying some parts plus what finish 62 - NCRS Discussion Boards
  • Jim H.
    • April 1, 2002
    • 112
    I have some brackets and some other parts which I am not sure what type of finish the parts should have nor where these parts go. Which parts should be painted (black or color of the car), blackened or plated?
    1.bolt.
    2. The small screw is a crutch head.
    3. BRAKE PEDAL PULL BACK SPRING PLATE. Paint black?
    4. thin nut
    Brackets (windshield)? Which ones should be plated or painted?
    1. bracket -
    2. bracket -
    3. bracket -
    4. bracket -
    1. Lag bolt??
    2. Two different screws with phillips heads.
    3. oval spacer?
    4. Brakes?
    5.
    6.
    Someone else took these parts off. I have to identify the parts and try to get the correct paint or plating applied.
  • Jim H.
    • April 1, 2002
    • 112
    Re: I need help identifying some parts plus what finish 62
    I figured out some of the parts. Deck lid shims and trunklid shims.
    Also, I painted the mounting brackets black.
