1972 LT-1 Carburator - NCRS Discussion Boards
    Re: 1972 LT-1 Carburator
    Originally posted by Bryan Montford (32138)
    Any comments about not having the A in the source #?
    Per Colvin's book, Holley says you won't see any "A" characters actually stamped on a carburetor as a suffix to the LIST number - only in the paper listings. They suffixed the stamped LIST number with -1, -2, -3, etc. to indicate changes in a production design (like the 2818 for '64, and the 2818-1 for 1965 as shown below).
      • 15573
      Gee John, I guess I am not seeing those List 6239A-1A stamps. In the old days I would have attributed this anomility to the beast, but I can't lay it at that doorstep anymore. I'll have to move up the eye surgery I have scheduled.
        • 11608
        #18
        I hope Colvin's book is more accurate than the magazine he produces.
        Patrick
        • Clem Z.
          • January 1, 2006
          • 9427
          #19
          Re: 1972 LT-1 Carburetor
          I think -- memory again -- that the R6239-1A was added to the TIM&JG in the last update, so Richard's information may be dated.
          the holley parts and specs catalogue shows R-6239-1A for LT-1 corvette S/T. it shows R-6239A but does not say corvette in the listing. could just be a printing error. the A carb shows 6828A and 4519 metering bodies and the -1A show 7102A and 7101A
          • Bryan M.
            • April 1, 1999
            • 386
            #20
            Does this carb fall within the guidelines of what is considered correct for my 72 LT-1?
            • Brad M.
              • July 31, 2005
              • 262
              #21
              Brian, that would seem to be within the allowed 6 months. The 1B2 would be 2nd week of December 1971 and your trim tag date indicates April 27th.
              Also, I looked at the extra 72 carb from lt-1 that I have and it has the following:
              3999263-GA
              List 6239-1
              241 (date code 1st week April 72)
              and metering plates have the 62391 on each and 7101 for one and 7102 for the other
              It also has an ink stamp of 4702D on the top.
              So it has the same numbers as yours.
              • Bryan M.
                • April 1, 1999
                • 386
                #22
                Thank you Brad. All is well.
                • Drew P.
                  • June 30, 1977
                  • 180
                  #23
                  3999263-GA
                  List 6239-1
                  Hello Bryan and Martin,
                  My 1972 coupe # 18,061
                  trim tag info:
                  I05 = body built April 5, 1972
                  945 = Bryar Blue paint
                  404 = black leather
                  engine assy:
                  V0329 CKY
                  carburator:
                  3999263-GA
                  6239-1
                  231 = 1972, March, first week
                  Drew Papsun
                  • Bryan M.
                    • April 1, 1999
                    • 386
                    #24
                    trim tag info:
                    404 = black leather
                    engine assy:
                    V0329 CKY
                    carburator:
                    3999263-GA
                    6239-1
                    Drew Papsun
                    Thanks for the info Drew. It looks like my carb falls in line with yours and Brad's extra carb<<<<<Martin
                      That's a February, 1971 carb - too early for your '72.
                      • Bryan M.
                        • April 1, 1999
                        • 386
                        #26
                        My NCRS manual shows for a Holley that a date code of 1B2 is
                        1=1971
                        B=December
                        2=week of month of production
                        I have the 3rd edition. Has the Holley Id section changed in the 4th edition?
                        • Brad M.
                          • July 31, 2005
                          • 262
                          #27
                          I thought it worked just like Bryan indicates above, months Jan to Oct are numbers 1 through 0, then they used A and B after they ran out of numberical digits.
                          Plus, the 71 lt-1 used 4801, so unless 6239 was used on some other application, there would not have been a reason for one to exist in Feb 71
                          • Roy V.
                            • April 8, 2008
                            • 296
                            #28
                            Bryan, my fourth edition TIM&JG has the same holley ID information as your third edition.
                            Regards
                              1=1971
                              B=December
                              Yup, you're right - brain fart on this end - somehow I read it as 122, not 1B2.
