Does Anyone Have A Secret For Removing And Installing Carpet Plugs In A C3 Corvette. Also Where Can You Purchase Repro Of These Plugs? I Got Some From Par---- But They Don't Match Up To The Originals.
Carpet Plugs
Re: Carpet Plugs
I "think" that Doc Rebuild has the correct plugs with the logos on them.
Check his site for more info.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Re: Carpet Plugs
When I installed mine in my 68 I put them in very hot water for a few minutes prior to installation to soften up the rubber, then I put a little white grease around the hole in the fiberglass floorboard where the plugs go and I used a drift pin large enough to fit inside the rubber plug and gently pressed it in to place. The drift pin stretches the tip of the plug enough to let it go into the hole without ripping through the end of the plug. Some guys use a phillips screwdriver but I did not like the idea that the tip of the screwdriver was pointed as it is easier to puncture th plug that way; the drift pin is flat at the tip and less likely to rip through the end of the rubber plug.
It was quick and easy.
Another way is to just get the rubber plug started in the holde form the interior side and then go under the car and GENTLY pull the tip the rest of the way through with pliers until you feel it seat itself in place.
Either method or a combination of both will work easily. Don't forget the small amount of grease to allow the plug to slide into place easier.
Kurt- Top
Re: Carpet Plugs
I've sucessfully removed PIF's by waiting for a warm day, using a pair of duckbill pliers and grabbing, gently squeezing and rocking the forward tip(s) as I pushed the PIF back through the mounting hole. Once out, they could be re-used...
On where to find correct originals, those I've removed had the GM PN (3776785 or 3868790, depends on year and application) embossed on the rear side rubber. If memory serves, this is what Paragon used to stock. But, check with the order desk to see if that's still true of their inventory.
On installing, Long Island carries a special tool (PN 55-48, $5.00) to insert the PIF's without breaking/tearing...- Top
Re: Carpet Plugs
Hello all,
Sounds like everyone is making this harder than it has to be. I placed mine (acquired from LIC) over each hole then pushed on the middle of the plugs with the rounded end of a screwdriver handle. Pop. Done. No heating, pulling or lubing. Maybe I'm missing something
Jeff- Top
Re: Carpet Plugs
I got some from Paragon within the last year and they were almost perfect, and judged without deductions. Maybe their product has changed?
- Top
Re: Carpet Plugs
Check the archives as John Hinckley outlined the process in a prior post. Basically, PIF's moist and heated and installed with a special tool not too dissimilar to the item I mentioned in the Long Island catalog...- Top
- Top
- Top
Re: Carpet Plugs
Thanks John! Your info on how it was done is always appreciated!
Steve- Top
