2 X 4 Air cleaner - NCRS Discussion Boards
2 X 4 Air cleaner
  • Mark P.
    • May 13, 2008
    • 934
    2 X 4 Air cleaner
    Does this look like an original un-sealed air cleaner ? I would like to use it on my late 1960.
    If so, any tips on how to restore the finish ? I was thinking I would lightly polish it with my Porter Dual action buffer.
  • Mark P.
    • May 13, 2008
    • 934
    Re: 2 X 4 Air cleaner
    This is supposed to be an original air cleaner. How can I tell ?
    Anyone running the K & N style element that Corvette Central sells ?
    • Roy B.
      • February 1, 1975
      • 7044
      Attached ImagesYour second attached pic. dont come in and cant tell if it is , make it bigger
      • Mark P.
        • May 13, 2008
        • 934
        Here is a bigger picture. Thanks Roy.
        • Roy B.
          • February 1, 1975
          • 7044
          OK looks original because the inner part looks spot welded (original), most repro's use a brass ring
          • Mark P.
            • May 13, 2008
            • 934
            I received my repro air cleaner from Paragon. It is made of steel. They told me it was aluminum. Lots of small scratches on the chrome.
            Will return it and try to restore the original I got off EBAY for $150.
            • Roy B.
              • February 1, 1975
              • 7044
              That's the 25% of money lost restoring a vett with repro's not made correct. Use your money and fix the real thing, and using steel wool on the air cleaner in a
              Circular direction will give it the original look.
              • Ian G.
                • September 3, 2007
                • 1114
                Hey Roy, so far I only lost about 5% to screw-ups. How am I doing? :P
                • Dennis A.
                  • April 30, 1999
                  • 1010
                  Do not buff or polish the air cleaner to a chrome-type finish...use the steel wool mentioned by Roy
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    Your doing good and it depends on how much more you need to go to finish
