70 Rear Suspension Rebuild? - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Well I started out just wanting to do the exhaust system. As I am sure you all can tell from my previous posts I am in the oh by the way mode
    What are the pros and cons of installing the exhaust system and going back later to do the rear suspension?
    Thanks!
    Bill
  • Michael G.
    • March 2, 2008
    • 485
    Re: 70 Rear Suspension Rebuild?
    Bill,
    All aspects of the rear are accessable with exhaust in place except the differential. Someone may give you a formula for that also, but not me. Even the spring can be extracted around the tubes. Mike
      • 3415
      Hi Bill,
      I think you're looking for an out!
      You want to be able to say... "they told me I HAD to do the rear suspension while the exhaust was off, honest".
      I think Michael is right. But the suspension is so vulnerable now!
      • Jim T.
        • March 1, 1993
        • 5351
        Bill what do you want to do to the rear suspension?
        • Steven G.
          • November 17, 2008
          • 348
          While looking at the rear suspension, and knowing the rear wheel bearings just need lubing, among other items perhaps, how about rear caliper shields that need plating, I think they can be unbolted without disturbing rear bearings and spacer clearance, with rotors + shoes off, can this be done? I,m not sure, it's been too many years ago. Steve
          • Michael G.
            • March 2, 2008
            • 485
            Sorry steve,
            You will need to pull the spindle to get the backing plat free.
            • Gary R.
              • April 1, 1989
              • 1796
              pulling the spindle will most likely wreck the bearings, so you'll be looking at rebuilding them.
              • Bill L.
                • February 1, 2004
                • 1403
                Hi Alan,
                You may be on to something
                I was not sure but what I do know is that the 70 has 115k miles so I was thinking that since it had never been apart that I might want to consider doing it while the exhaust was removed.
                I may wait now just so I can get it back together to drive this summer.
                Bill
                  • 3415
                  Hi Bill,
                  Well............. there does seem something attractive about being able to drive it.
                  Lots of Fun in lots of DIFFERENT ways.
                  • Steven G.
                    • November 17, 2008
                    • 348
                    I found a previous post "rear wheel bearing assy" 2008' Joe Luca,s reply, the rear caliper plates can be installed without disassembly of rear bearing unit with rear shoes removed. So, I am correct, as I recalled from years past, this can be done without disturbing bearings and or clearances.
