I will be installing a T-10 in my 1960 in the next month and wanted to know are there any special tools (i.e. an alignment tool) I need to get the linkage adjusted properly.
I was planning to put my engine on a cherry picker and install the flywheel, bellhousing, clutch assembly and clutch fork. I was then planning to set the T-10 on a table and bolt it to the bellhousing then install the OEM shifter and linkage.
Any advice on getting the linkage set properly ? Is there a lot that can go wrong ? Will I need to be able to depress the clutch fork ?
The linkage is new from Paragon. Since I had a Muncie in my car and a Hurst shifter, I have no reference from any of that set-up.
Oh and lots of rags to put on parts of the motor so no scratches.
