75-7 Catalytic Converter Rear Hanger Brkt - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    First part...Regarding the Hanger Bracket that connects the rear of the Converter, the Exhaust Pipe and the heat Shield to the Frame. What is the color of the Hanger and Special Washers riveted to the Rubber Dampers. Also, the loose Special Washers and Bolts that connect the whole thing to the Frame.
    Second part...Regarding the triangular Heat Shield that clamps in three places to the rear Y-Pipe. I'm looking for the clamps...Any help?
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
  • Michael B.
    • April 1, 1999
    • 178
    Re: 75-7 Catalytic Converter Rear Hanger Brkt
    Alger, I just got the 77 hanger (sits in front of the y-pipe, behind the catalyst) shipped from Denver. It was rusted (the hangers, washers) which means it was natural uncoated steel. The bolts looked like phosphate black.
    You can check with Keith at Corvel if he has clamps but I suspect he would have sent them to me as well. From the assembly manual the clamps look like the same type as may be available today from parts suppliers but I have to check for myself as well.
    Hope that helps.
    Michael B.
