three twos - NCRS Discussion Boards
three twos
  • Phil A.
    • April 30, 1982
    • 121
    three twos
    1968 vette middle carb of a 3/2 set up with 4 speed- kick down throttle linkage interfers with the valve cover. How do I fix this problem short of cutting the kick down off? Thanks Phil
  • Jay G.
    • April 30, 2001
    • 63
    Re: three twos
    Are you referring to the factory tripower setup or is this an aftermarket setup?
    On my '69 manual tripower there isn't any linkage other than the A/C idle solenoid and the linkage that makes sure that the secondary carbs are closed at idle.
    Do you have any pictures you can post?
    Jay
    • Michael B.
      • June 18, 2007
      • 400
      Re: three twos
      I don't see any portion of the linkage that is close to the valve cover. "Kick-Down" usually refers to a link, cable or rod, to the automatic transmission. Are you referring to the throttle cable bracket that is attached to the rear carb base bolts on the driver's side?
      The secondary linkage is vacuum open on the passenger side and mechanical close on the driver's side. The only other link at the carbs are the fuel lines and the idle solenoid as Jay said.
      • Jack C.
        • September 30, 1992
        • 1090
        Re: three twos
        68 400 hsp.
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Mark K.
          • January 1, 1983
          • 148
          Re: three twos
          Originally posted by Jack Corso (21713)
          68 400 hsp.
          Wow. I'm not really as familiar with C3 435s (mine is a 67 435), but did GM really hang the return spring on the fuel line?
          1967 L71 Silver/Black Coupe - Unrestored/Original Paint, Top Flight at 1998 Regional in Ontario, not judged since
          1995 Red/Red ZR-1 - Top Flight back in 2010 Michigan Chapter meet
          • Jack C.
            • 1090
            Re: three twos
            I believe this is true. Early 68
            Jack Corso
            • Michael B.
              • June 18, 2007
              • 400
              Re: three twos
              No, there should be a spring that extends rearward from the throttle shaft to a small hole in the cable bracket.
              • Jack C.
                • 1090
                Re: three twos
                The short yellow spring, MAY have been on later 68's in addition to the main spring. The orange was on 69's per the TGJM. The main spring is correct on the 68.
                Jack Corso
                • John M.
                  • January 1, 1998
                  • 813
                  Re: three twos
                  I had this same problem, using a service replacement (67 center carb) on a 69 intake. I cut the piece off. I don't know if the service replacement was for 67 only or for all (with adjustments)
                  JBMcRae 30025
                  • Jay G.
                    • April 30, 2001
                    • 63
                    Re: three twos
                    Originally posted by John McRae (30025)
                    I had this same problem, using a service replacement (67 center carb) on a 69 intake. I cut the piece off...
                    John,
                    Can you be more specific as to what part you cut off?
                    Jay
                    • John M.
                      • January 1, 1998
                      • 813
                      Re: three twos
                      Jay, It was part of the lever on the center carb throttle shaft. It was hitting the valve cover. My original dated 69 center carb did not have it. I'll get a photo tonight and post tomorrow.
                      • Jay G.
                        • April 30, 2001
                        • 63
                        Re: three twos
                        Thanks. I am curious to see a pic as I have a service carb that has a throttle lever that doesn't look like a production carb. I don't have any problems with my throttle sticking at the moment but maybe I have just been lucky. Hopefully I don't find out the hard way. Getting my accelerator pedal stuck under the floor mat once was exciting enough for me.
                        Jay
                        • John M.
                          • January 1, 1998
                          • 813
                          Re: three twos
                          Jay,
                          The first picture is of a correct 69 L71 carb with the lever attached. The second is a 427 400 with the service carb with the piece of the lever that was hitting cut off.
                          John
                          • Phil A.
                            • April 30, 1982
                            • 121
                            Re: three twos
                            John, you hit the nail on the head, that was exactly what I was asking. Thanks so much, and I thank everyone else for their replys. Phil
