1968 vette middle carb of a 3/2 set up with 4 speed- kick down throttle linkage interfers with the valve cover. How do I fix this problem short of cutting the kick down off? Thanks Phil
three twos
Re: three twos
Are you referring to the factory tripower setup or is this an aftermarket setup?
On my '69 manual tripower there isn't any linkage other than the A/C idle solenoid and the linkage that makes sure that the secondary carbs are closed at idle.
Do you have any pictures you can post?
Jay- Top
Re: three twos
I don't see any portion of the linkage that is close to the valve cover. "Kick-Down" usually refers to a link, cable or rod, to the automatic transmission. Are you referring to the throttle cable bracket that is attached to the rear carb base bolts on the driver's side?
The secondary linkage is vacuum open on the passenger side and mechanical close on the driver's side. The only other link at the carbs are the fuel lines and the idle solenoid as Jay said.
- Top
Jack Corso
1972 Elkhart Green LT-1 Coupe 43,200 miles
Top Flight 1994, 2018 & 2021- Top
1967 L71 Silver/Black Coupe - Unrestored/Original Paint, Top Flight at 1998 Regional in Ontario, not judged since
1995 Red/Red ZR-1 - Top Flight back in 2010 Michigan Chapter meet- Top
- Top
Re: three twos
The short yellow spring, MAY have been on later 68's in addition to the main spring. The orange was on 69's per the TGJM. The main spring is correct on the 68.Jack Corso
Re: three twos
Thanks. I am curious to see a pic as I have a service carb that has a throttle lever that doesn't look like a production carb. I don't have any problems with my throttle sticking at the moment but maybe I have just been lucky. Hopefully I don't find out the hard way. Getting my accelerator pedal stuck under the floor mat once was exciting enough for me.
Jay- Top
Re: three twos
Jay,
The first picture is of a correct 69 L71 carb with the lever attached. The second is a 427 400 with the service carb with the piece of the lever that was hitting cut off.
John- Top
