I need to do a trailing arm restoration on my '72 and I know what's going to happen. I'll get the trailing arms off and then decide I cannot stop and before you know it the body will be off the car for a full chassis restoration
. Thus in anticipation of that event, here is something I've been wondering.
It's obvious that the external surfaces of the frame can be restored but what of the inside surface areas? I know by looking in the holes in the frame rails that there is a good bit of rust in there too. So what can be done with the internal surfaces of the frame? Is it just a matter of finding a shop that can dip the frame to remove rust and then again to coat the internal surfaces with something?
Any experience others have had related to this would be appreciated.
. Thus in anticipation of that event, here is something I've been wondering.It's obvious that the external surfaces of the frame can be restored but what of the inside surface areas? I know by looking in the holes in the frame rails that there is a good bit of rust in there too. So what can be done with the internal surfaces of the frame? Is it just a matter of finding a shop that can dip the frame to remove rust and then again to coat the internal surfaces with something?
so it has become an effort to produce the best possible outcome from each step. Thanks and regards...joe
