i have a 67 and it normally starts and runs fine. yesterday i turned the key and there was no sound at all... im certain its not the battery as all the gauges, clock, lights etc work... i dont know much about cars,, anyone have any idea on what i should trouble shoot first??
no noise at all when i turn the key
Re: no noise at all when i turn the key
Things to check.
Bulkhead connection at the firewall.
Do you have a green knob battery disconnect ?? If you do, take it off.
Possible starter solenoid.
Bad battery cable connection.
Those are the items I'd check first.
If the car is an auto, check the nuetral safety switch and make sure the car is in park !Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
Dan;i have a 67 and it normally starts and runs fine. yesterday i turned the key and there was no sound at all... im certain its not the battery as all the gauges, clock, lights etc work... i dont know much about cars,, anyone have any idea on what i should trouble shoot first??
In addition to what Tom said, I would tap the starter solenoid with a hammer, gently... that is after you check the other stuff he mentioned.
Good luck,
Joel- Top
Dan, Id Like To Add A Thing If These Others Dont Work, Saftey Switch On Clutch Pedal If 4 Speed Or Automatic Try Moving Gear Slector Into Netural. Hope All Goes Well.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Check the battery cables at the battery and clean and grease the terminal connections.
Had the same problem a few years ago. Same night the hood release cable broke followed by an argument with the insurance about flat bedding it home and not on a hook. I won, paid the difference, but they paid most of the tow.
DonThe light at the end of the tunnel has been turned off.- Top
Before you do anything else. Yoy said you had lights and gauges. Turn the headlights on have someone watch the lights. Then hit the starter. See if the headlights go dim or out. If they do it is the battery or battery connection. This is always my first check, I am a C-2 guy I dont know about late models. Dale- Top
Since you don't know much about cars I should not tell you about using a screwdriver to touch the small terminal on the starter solenoid to the battery cable connection on the solenoid and see if the starter turns over. With the key on it could start, make sure the car is in park or neutral.- Top
