'55 exhaust gaskets - NCRS Discussion Boards
'55 exhaust gaskets
  • Michael L.
    • July 31, 2005
    • 562
    '55 exhaust gaskets
    Anyone know which type of gaskets are used to seal the pipes to manifolds? Are sintered donuts used? I have paper gaskets with metal internal rings for the heat riser, is anything else used on either pipe? If so, what is correct install? In taking out my motor for rebuild, I noticed a look of exhaust on block. More than I expected for short use. Thanks!
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '55 exhaust gaskets
    Originally posted by Michael Lander (44237)
    Anyone know which type of gaskets are used to seal the pipes to manifolds? Are sintered donuts used NO? I have paper gaskets with metal internal rings for the heat riser, is anything else used on either pipe? If so, what is correct install? In taking out my motor for rebuild, I noticed a look of exhaust on block. More than I expected for short use. Thanks!
    That's it just a exshust gasket with metal rings both sides , Donuts are for cops will you be going to Tahoe
    • Michael L.
      • July 31, 2005
      • 562
      I'll be in Incline Sunday, when are you leaving? I'll probably cruise over in the AM, but not in the Corvette.
      • Roy B.
        • February 1, 1975
        • 7044
        Saturday night it's only two hours from home
