Anyone know which type of gaskets are used to seal the pipes to manifolds? Are sintered donuts used? I have paper gaskets with metal internal rings for the heat riser, is anything else used on either pipe? If so, what is correct install? In taking out my motor for rebuild, I noticed a look of exhaust on block. More than I expected for short use. Thanks!
'55 exhaust gaskets
Tags: None
Re: '55 exhaust gaskets
That's it just a exshust gasket with metal rings both sides , Donuts are for copsAnyone know which type of gaskets are used to seal the pipes to manifolds? Are sintered donuts used NO? I have paper gaskets with metal internal rings for the heat riser, is anything else used on either pipe? If so, what is correct install? In taking out my motor for rebuild, I noticed a look of exhaust on block. More than I expected for short use. Thanks!
will you be going to Tahoe
I'll be in Incline Sunday, when are you leaving? I'll probably cruise over in the AM, but not in the Corvette.- Top
