LT-1 Holley Carb Problem Help - NCRS Discussion Boards
  • Bryan M.
    • April 1, 1999
    • 386
    Re: LT-1 Holley Carb Problem Help
    Ok, here's the low down.
    Clem, no clutch head screwdriver at the Sears in my neck of the woods. Larry, I did find an old dusty one at a True Value Hardware store.
    I did figure out what was causing my accelerator pump lever to bind up and not pump.
    There was a blockage between the acc. pump passengeway and the shooter nozzles. This caused the pump pressure to deadhead after the bowls filled with gas. Blowing out the passage way cleared the obstruction.
    I went ahead and replaced the old black rubber accelerator pump (I didn't see anything wrong with it)with a Holley green 30cc shot, replaced all gaskets and set the floats and acc. pump lever to specs. The power valves looked good and held vacuum in the diaphagm. So I left the originals in.
    There was one thing I noticed that is different about the Holley replacement power valves and the the ones in my carb. The power valves in my carb have 4 slots and the Holley's have only 2 slots. I don't know what performance difference this would make, if any.
    I filled the bowls with gas and did a trial run on my carb stand. I got a nice even shot of gas out of the shooter nozzles when the acc. pump was activated.
    I just finished putting the carb back on and firing her up for a test run.
    The engine fires right up and is running smooth and has a nice crisp off idle acceleration. Blip the gas=instant response
    Thanks guys for all the tips and help!
    • Jim T.
      • March 1, 1993
      • 5351
      Bryan what did you find blocking the accelerator pump?
      • Bryan M.
        • April 1, 1999
        • 386
        Jim,
        I'm not sure what it was. I had the nozzle off and the discharge needle out, when the air broke free, it shot a spray of gas in the air.
        • Sandra H.
          • August 29, 2007
          • 262
          Corvette Central also sells a set of clutch head screwdrivers (5/32" to 5/16") to fit all the different sizes of them used on C1's; have had mine for many years.
          Thanks, John, for the photo....another set of my "mystery" tools explained.
          Sandy
