I have a 63 SWC with a B/W 4speed. My speedo stopped working, removed the speedometer fitting assy. Found, that the plastic gear (Green-22 teeth) was worn (flattened) on one side, less that 1/2 way around. What would cause this wear ?
The gear was not in there very long, has less than 200 miles on it, since I had it installed, when I had the car worked on.
I have ordered a replacement fitting and gear from Paragon. The old gear was slightly sloppy in the fitting, but otherwise not too bad, aside the wear on the teeths. The long shaft of the plastic gear was not worn.
Just curious, what did the damage...
Rainer
Rainer
