Re: 63 speedo gear
Scott-----
As you mention, the speedometer DRIVE gear in the transmission is steel and is pretty much "indestructible". However, it can easily be installed at the wrong position on the main shaft. If it's off even a little bit, improper meshing of the drive and driven gears can occur. This is true of all 57-63 T-10's, 63-67 Muncies, and 71-74 Muncies. 1968-70 Muncies use a nylon drive gear with special retainer that ensures proper positioning of the drive gear.
If the 22 tooth green driven gear is the correct one for this car, it is available under GM #3860345.
Scott-----
