Re: 67 Gauge cluster removal advice
Ara,
Like Jack H says in the other thread, it is a piece of cake getting to the brake switch. You just have to contort your body to get your head and arms under the dash, upside down on your back. Ouch
. You're are a lot younger than Jack or I, and I'm sure you can do it with a lot more flexibility.
If you are going to address both the amp gauge and the brake switch, the ultimate in comfort would be to take the drivers seat out (4 easy bolts on a 67) and use some strategically place pillows. Still after you are done, take two Advils before you go to bed.
Have fun,
Ara,
. You're are a lot younger than Jack or I, and I'm sure you can do it with a lot more flexibility. If you are going to address both the amp gauge and the brake switch, the ultimate in comfort would be to take the drivers seat out (4 easy bolts on a 67) and use some strategically place pillows. Still after you are done, take two Advils before you go to bed.
Have fun,
. That probably should be the very next things to check.
