removal of spinners from 60 wheel covers - NCRS Discussion Boards
  • Valeria H.
    • July 27, 2009
    • 463
    I admit my ignorance but I just purchased a set of 4 wheel covers with spinners in the era of "60 and need to be able to get the spinners off the wheel covers without damage so I can send them to be rechromed. Can anyone tell mehow to remove the spinners from the wheel covers without compromising either part?
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
  • Chuck W.
    • May 31, 2002
    • 257
    Re: removal of spinners from 60 wheel covers
    Valeria
    1 Soak the screws in penetrating oil.
    2 Using a thick towel or blanket, place hubcap upside down on your lap.
    3 Using the appropriately sized phillips screwdriver, place screwdriver in each screw and firmly tap with a hammer.
    4 Unscrew screw.
    5 If screw head is stripped or damaged, carefully use a die grinder and remove the head of the screw and then work thread portion out with vice grips.
    6 Drink a beer.
    7 Repeat
    • Valeria H.
      • July 27, 2009
      • 463
      Thank you so much for your blow by blow explanation. That is exactly what I needed to hear, but will it still work if I substitute wine in place of the beer??
      Valeria Hutchinson
      • Chuck W.
        • May 31, 2002
        • 257
        Only if you repeat.
