63 Rocker Panel brackets
Re: 63 Rocker Panel brackets
Ken- Top
Thanks for the information about the pop rivets.
My coupe is 031XX built second week November 62 and I can tell you for a fact the rocker panels had two holes in each end. I can't attest as to the brackets because the fenders had been replaced.- Top
Hi Tim, As you can tell from what I am gathering here your car may not have come with the brackets. Do your rocker panels have evidence of screws previously being used in the firs or 2nd hole in the bottom of the rockers?
Joe- Top
Joseph,
My memory tells the two holes were used and there was evidence. The rockers have departed life with me... They were junk but I should have saved them..- Top
[quote=Joseph Scafidi (8321);456096]Does anyone have info for approximate vin when the small rocker panel bracket was riveted to the inside of the lower front fender extension.
I have an early car 1022 without it and no holes ever drilled, a late car 21,000 with the brakets riveted in, and a friend with a 9,000 serial number car with the brackets who lost points at judging for having them.
Do we think the installation of the bracket is somehow tied into the change from 2 exterior screws at each end of the rocker panel to 1 screw at each end?
Joe, Sorry for giving you bad info on my 9900 car. It does NOT have the brackets. John- Top
