After having my '66 427 fully rebuilt and now run-in (1:45 run time) am experiencing something at a loss to understand. Engine powers up, runs and sound very good. Ran the engine again tonight have noticed after serveral minutes of running see minscule......minscule bubbles every so often between the head and block at the back of engine where the head gasket can marginally be seen. I got my machinest over to let him see the engine from it's cold state to a complete "up to temp" running engine. He's scatching his head as well
. Block and heads where manafluxed with heads slightly milled. Engine temps out around 190*-200*. I'm going to pull the engine back down to check for head gasket issues as I've nor him has not seen something like this at this location on the engine. Not sure if this is an issue but doesn't seem it would be normal for big block Chevy........or even a small block for that matter!
Lastly....Fel Pro head gasket was gasket of choice.....any advantage to Victor or Mr. Gasket head gaskets? Thanks in advance
. Block and heads where manafluxed with heads slightly milled. Engine temps out around 190*-200*. I'm going to pull the engine back down to check for head gasket issues as I've nor him has not seen something like this at this location on the engine. Not sure if this is an issue but doesn't seem it would be normal for big block Chevy........or even a small block for that matter!Lastly....Fel Pro head gasket was gasket of choice.....any advantage to Victor or Mr. Gasket head gaskets? Thanks in advance
. Please explain. Thanks.
