Re: Fel Pro head gaskets compared to Victor
I see that the head gasket is a FelPro 8180PT2: composition type, "Permatorque" .039" compressed thickness. Much more forgiving than the original steel shim, so there must be a GROSS imperfection in the deck near where the leak is. Did you examine the heads after they were surfaced?
I agree that putting a band aid on it is the wrong way to go. You should investigate what is causing the problem.
Depending on which side the leak is on, was #7 or #8 hole sleeved?
I would pull the heads to check all surfaces. IF YOU DECIDE TO DO THIS, AND ONLY IF YOU DO THIS, then try to get your engine to detonate before dismantling it. If it won't detonate I would consider using a thinner head gasket than what's on there now.
Mr. Gasket 5802 is a good choice.
