Does anyone have a good source for buying a RH valve cover engine suffix code label that will pass NCRS judging for a 1970 Corvette? I can find them for 1968 and 1969 Vettes, but not 1970.
350/350 RH Valve Cover Engine Suffix Label
Re: 350/350 RH Valve Cover Engine Suffix Label
Hi Duane,
I believe Patrick Hulst has helped some members with the suffix lables. I don't think anyone is reproducing them as an enterprise. I bet he'll pipe up.
Here's the original from my 71, 350/270. I retrieved the picture from a post from last year. I post it just to give you an idea of the configuration in 71.
Chapter Top Flight October 2011- Top
Duane, I Used My Computer To Make Up My Own, It Takes Alittle Time To Get The Letter Size And Font And Color Correct.
Allans Measurments Should Help With The Sizing Of The The Letters.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
- Top
Per rules, we're not supposed to solicit business on this site.
So, I'll just say that the answer is posted above.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Patrick, could post a pic. of the label you made, I would like to compare the one I made.thanks EdNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Sorry Ed.
I've put a lot of time and effort and even money into getting my labels as correct as possible. I lose money on every one of them and while I would not mind comparing I'm not up to posting my efforts for everyone to download and print. I do not sell labels to make money but rather to help the hobby and the nominal cost I ask only defrays a small part of the expenses. Those who happen to purchase from me understand this.
Pat understood , I beleive you ve got a good point there.I wasn't thinking. I didnt realize that someone could make one from your picture on the site.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
- Top
The originals (and some reproductions
) are self-adhesive. I suspect that some type of contact cement would work if one felt the need to add "extra" glue.
Remember the original glue only had to hold until the engine was installed int he chassis. My suspicion is that it did not react well to heat and that is the reason we see so few originals.Terry- Top
Based on the residue I've seen -and own - on original valve covers I think you are correct.Vice-Chairman (West), Michigan Chapter NCRS
