350/350 RH Valve Cover Engine Suffix Label - NCRS Discussion Boards
  • Duane D.
    • April 15, 2009
    • 67
    Does anyone have a good source for buying a RH valve cover engine suffix code label that will pass NCRS judging for a 1970 Corvette? I can find them for 1968 and 1969 Vettes, but not 1970.
    • 3415
    Re: 350/350 RH Valve Cover Engine Suffix Label
    Hi Duane,
    I believe Patrick Hulst has helped some members with the suffix lables. I don't think anyone is reproducing them as an enterprise. I bet he'll pipe up.
    Here's the original from my 71, 350/270. I retrieved the picture from a post from last year. I post it just to give you an idea of the configuration in 71.
      • 6940
      Duane, I Used My Computer To Make Up My Own, It Takes Alittle Time To Get The Letter Size And Font And Color Correct.
      Allans Measurments Should Help With The Sizing Of The The Letters.
      • Bill C.
        • July 15, 2007
        • 904
        I had Patrick make mine for me.
        EXCELLENT work - dead on correct.
        • Stephen B.
          • April 1, 1988
          • 876
          Consider using manilla folder for the paper.
          • Joseph M.
            • June 30, 1999
            • 334
            I just did a search and in 2000 Patrick Hulst posted saying he was considering making these labels. Does anyone know if he is doing reproductions? Better yet, maybe Patrick can respond.
              • 11608
              Per rules, we're not supposed to solicit business on this site.
              So, I'll just say that the answer is posted above.
              Patrick
                • 6940
                Patrick, could post a pic. of the label you made, I would like to compare the one I made.thanks Ed
                  • 11608
                  Sorry Ed.
                  I've put a lot of time and effort and even money into getting my labels as correct as possible. I lose money on every one of them and while I would not mind comparing I'm not up to posting my efforts for everyone to download and print. I do not sell labels to make money but rather to help the hobby and the nominal cost I ask only defrays a small part of the expenses. Those who happen to purchase from me understand this.
                  Patrick
                    • 6940
                    Pat understood , I beleive you ve got a good point there.I wasn't thinking. I didnt realize that someone could make one from your picture on the site.
                    • Stephen B.
                      • April 1, 1988
                      • 876
                      Here's a 1970 CTU I obtained from the Forum.
                      • Larry E.
                        • 1652
                        Hello:
                        What kind of glue is recommended as there is a lot of heat in this area?
                        Thanks; Larry
                        Larry
                        LT1 in a 1LE -- One of 134
                          • 11608
                          Originally posted by Larry Evoskis (16324)
                          Hello:
                          Thanks; Larry
                          The originals (and some reproductions ) are self-adhesive. I suspect that some type of contact cement would work if one felt the need to add "extra" glue.
                            • 15573
                            Remember the original glue only had to hold until the engine was installed int he chassis. My suspicion is that it did not react well to heat and that is the reason we see so few originals.
                              • 11608
                              Based on the residue I've seen -and own - on original valve covers I think you are correct.
