I am looking at a 67 convertible 327-350hp. The vin # is 194677S106292 and the # on the engine pad is 7106291V1207HD. Should it read 7106292? Thanks for your help. Joe DeLuca Member 37862
1967 vin - engine pad #
Re: 1967 vin - engine pad #
Bob, Thanks for your reply.I thought that the both numbers should match. I guess it would be consider a non matching number car. I am not sure what that does to the value of the car. It is 1 number off. I really like the car, that's my only issue.- Top
Joe:
Did you get a picture of the pad? A build sheet would also be nice. If so, I would post it and get some opinions. Being just on number off would lead me to believe it is some sort of anomaly. It certainly from a "buyers standpoint" would be a non matching numbers car. However, it could be one of great interest to those in the know.
I had a 67 that I never understood. The hand written number on the build sheet (353) was one digit off of what was written behind the tank (354) and on the front passenger side. Go figure.
If you like it, buy it!- Top
Joe,
It's either a factory stamping error, or the block came from a donor car whose Vin Number was 6291. Unless the owner has documentation to prove that this is a factory stamping error, I would consider this as s "non-matching numbers car".
John- Top
Look at the transmission stamp. stamped at the same time by the same stamp. If both the same, very likely a factory error. Any paperwork? Tank sticker to verfly options?Bill Clupper #618- Top
- Top
Pat, I have some pictures in my email. If you send me your email adress I will send them to you. I do not know how to post them here. I am still feeling my way on the computer. I would like your opinion. I don't want to make a mistake buying a car. The car is a 327-350hp, 4 speed, pwr steering, has the hardtop. Thanks, Joe- Top
Ok Joe, send them to me and I will post them here. PTPat, I have some pictures in my email. If you send me your email adress I will send them to you. I do not know how to post them here. I am still feeling my way on the computer. I would like your opinion. I don't want to make a mistake buying a car. The car is a 327-350hp, 4 speed, pwr steering, has the hardtop. Thanks, Joe
- Top
Joe, I replied to your email. I did get the three pictures you sent but I cannot get them to load onto the internet and I've tried 3 different places including here. I don't know what the problem is. PT- Top
Joe,
Maybe we are looking at this backwards.
If the VIN plate says "91" and
The stamp pad says "91" and
The trans ends up showing "91"...
Then the question becomes: Where did the "92" come from?
Perhaps a confused owner or a typo on the Title?
Good Luck and keep us posted.
HaND- Top
