1967 vin - engine pad # - NCRS Discussion Boards
  • Joe D.
    • April 30, 2002
    • 382
    I am looking at a 67 convertible 327-350hp. The vin # is 194677S106292 and the # on the engine pad is 7106291V1207HD. Should it read 7106292? Thanks for your help. Joe DeLuca Member 37862
  • Bob H.
    • July 31, 2000
    • 789
    Re: 1967 vin - engine pad #
    Hi Joe It should match exactly but is very strange to be just a digit off.Another factory screwup? The HD indicates it should be a 4 speed with Air Injector Reactor. My car is 106702
    Bob
    • Joe D.
      • April 30, 2002
      • 382
      Bob, Thanks for your reply.I thought that the both numbers should match. I guess it would be consider a non matching number car. I am not sure what that does to the value of the car. It is 1 number off. I really like the car, that's my only issue.
      • Bob H.
        • July 31, 2000
        • 789
        Joe:
        Did you get a picture of the pad? A build sheet would also be nice. If so, I would post it and get some opinions. Being just on number off would lead me to believe it is some sort of anomaly. It certainly from a "buyers standpoint" would be a non matching numbers car. However, it could be one of great interest to those in the know.
        I had a 67 that I never understood. The hand written number on the build sheet (353) was one digit off of what was written behind the tank (354) and on the front passenger side. Go figure.
        If you like it, buy it!
        • John S.
          • September 30, 1997
          • 263
          Joe,
          It's either a factory stamping error, or the block came from a donor car whose Vin Number was 6291. Unless the owner has documentation to prove that this is a factory stamping error, I would consider this as s "non-matching numbers car".
          John
          • William C.
            • May 31, 1975
            • 6037
            Look at the transmission stamp. stamped at the same time by the same stamp. If both the same, very likely a factory error. Any paperwork? Tank sticker to verfly options?
            Bill Clupper #618
            • Dick W.
              • 10483
              It most certainly would not be the first factory mis-stamp!
              Dick Whittington
              • Joe D.
                • April 30, 2002
                • 382
                I contacted the owner. He has the car stored. He is going to double check the numbers tomorrow. I will post his findings. Thanks, Joe
                • Patrick T.
                  • September 30, 1999
                  • 1286
                  Joe, did you take any pictures of the car? PT
                  • Joe D.
                    • April 30, 2002
                    • 382
                    Pat, I have some pictures in my email. If you send me your email adress I will send them to you. I do not know how to post them here. I am still feeling my way on the computer. I would like your opinion. I don't want to make a mistake buying a car. The car is a 327-350hp, 4 speed, pwr steering, has the hardtop. Thanks, Joe
                    • Patrick T.
                      • 1286
                      Ok Joe, send them to me and I will post them here. PT
                      • Joe D.
                        • April 30, 2002
                        • 382
                        I just received a email from the owner. He had pictures of the vin tag. It is 194077S106291. He is going to check the engine pad again tomorrow. I hope it matches! Thanks, Joe DeLuca
                        • Patrick T.
                          • 1286
                          Joe, I replied to your email. I did get the three pictures you sent but I cannot get them to load onto the internet and I've tried 3 different places including here. I don't know what the problem is. PT
                          • Mike M.
                            Director Region V
                            • August 31, 1994
                            • 1464
                            Joe,
                            Maybe we are looking at this backwards.
                            If the VIN plate says "91" and
                            The stamp pad says "91" and
                            The trans ends up showing "91"...
                            Then the question becomes: Where did the "92" come from?
                            Perhaps a confused owner or a typo on the Title?
                            Good Luck and keep us posted.
                            HaND
                            • Joe D.
                              • April 30, 2002
                              • 382
                              Mike, He originaly said the vin was 92. After i questioned him he said he had some pictures on his computer of the vin tag and sent them. I want to make sure to engine pad is correct and the title. Thanks, Joe
