Judging on posi units - NCRS Discussion Boards
  • Chris S.
    • March 28, 2007
    • 139
    For flight judging is it recommended to have correct posi unit (date and stamped coded). I beleive i have a car with a service replacement, after reading many of the old post out there i am not sure what to do with it? Do i search for the correct unit or take the deduction? Opinions are appreciated.
  • Mark K.
    • January 1, 1983
    • 148
    Re: Judging on posi units
    The dates annd stampings on the differential are not judged. A service replacement - visually the same as an original - will not lose points.
    1967 L71 Silver/Black Coupe - Unrestored/Original Paint, Top Flight at 1998 Regional in Ontario, not judged since
    1995 Red/Red ZR-1 - Top Flight back in 2010 Michigan Chapter meet
    • Chris S.
      • March 28, 2007
      • 139
      thanks for the info
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Chris,
        Experienced Chassis and Interior Judges will, however, work together to confirm that a car with the Posi Instructions under the Jack Cover will also have a posi tag on the unit and Vice-Versa, or, both locations without.
        HaND
        • Chris S.
          • March 28, 2007
          • 139
          thanks
          i was kinda concerned because the unit i have is a 3789812
          cast date H275 with a thin p. Didn't know if i was getting to picky for the flight judging? Or do i need to track the correct unit down?
          My car is a late 57 (5277)
          thanks
          • Gary C.
            Administrator
            • October 1, 1982
            • 17549
            Chris, the revised 5th edition 56-7 JM removed all of the "not judged" statements. Anything a Judge can see or get to underneath that's in the JM will be judged. '57 posi unit info is in the 5th edition. Gary....
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • Chris S.
              • March 28, 2007
              • 139
              so if i read you right, start looking for a new unit? the 5th edition is a great book.
