Well today I installed the rear control arms /diff and Leaf spring.
for some reason the spring pad doesn't line up exactly with the control arm pad the bolt is at an angle. I bought the rear spring mounting kit from vette products. The pads seem so thick that I don't have room for the rear stabilizer hardware. Any suggestions. I converted the rear trailing arms to disk brakes from Blairs and got the frame from Collier tec .
After getting it together I noticed the side yoke coming out from the case I guess the slip ring wasn't put in properly from a local transmission shop
All taken apart . Cheers
