went to order r45xls plugs for my l36 they have 2 different versions and neither say they're for my car but was going to use them anyway but they have one that shows a cap and one that don't? which of the 2 do I need they're the same part number except the 6 at the end of the one with a cap.
went to order plugs from summit but got confused on this..
Tags: None
- Top
Re: went to order plugs from summit but got confused on this..
OK.... IF the plug has a "removable" top cap... yes , you would need it to connect a standard auyomotive connection . But, I'm not aware that ALL plugs have a removable cap .... I could be wrong !- Top
Go to the Summit link and look at the plugs, it is as plain as day and nightDick Whittington- Top
Brandon, you need the terminal cap that threads onto the terminal end so you can snap the plug wire onto it. I've been changing plugs since 1967 and automotive plugs used a cap well before then.went to order r45xls plugs for my l36 they have 2 different versions and neither say they're for my car but was going to use them anyway but they have one that shows a cap and one that don't? which of the 2 do I need they're the same part number except the 6 at the end of the one with a cap.
http://www.summitracing.com/search/?...F-R45XLS&dds=1
I think that some uses of spark plugs call for a plug wire with a spade connection, which fits onto the terminal end and is held on with nuts. I've never seen one of these, so I could be wrong.
Paul- Top
Paul, I think that type connection predates us a few years.
I have done restorations on '20's vintage vehicles and that is what was used. Along with lacquered fabric covered plug wires.
- Top
a lot of performance spark plugs have the screw on caps so they can be used with either types of plug wire ends- Top
- Top
a lot of off road vehicles like dirt bikes,quads and snowmobiles use the plug with just the threaded part showing and you have to remove the screw on cap.- Top
so which do I order neither says they're recommended for my car..but I know a lot of people run them and like them.- Top
Brandon,
Have you tried a local parts store like NAPA or even Auto Zon e, Pep Boys or others?
Most carry many types and brands of plugs. I get AC, Autolite and others for about $2.50 each.- Top
Do you need 100? In my crap
Attached FilesDick Whittington- Top
