went to order r45xls plugs for my l36 they have 2 different versions and neither say they're for my car but was going to use them anyway but they have one that shows a cap and one that don't? which of the 2 do I need they're the same part number except the 6 at the end of the one with a cap.
went to order plugs from summit but got confused on this..
Tags: None
- Top
Re: went to order plugs from summit but got confused on this..
OK.... IF the plug has a "removable" top cap... yes , you would need it to connect a standard auyomotive connection . But, I'm not aware that ALL plugs have a removable cap .... I could be wrong !- Top
Go to the Summit link and look at the plugs, it is as plain as day and nightDick Whittington- Top
http://www.summitracing.com/search/?...F-R45XLS&dds=1
I think that some uses of spark plugs call for a plug wire with a spade connection, which fits onto the terminal end and is held on with nuts. I've never seen one of these, so I could be wrong.
Paul- Top
Paul, I think that type connection predates us a few years.I have done restorations on '20's vintage vehicles and that is what was used. Along with lacquered fabric covered plug wires.
- Top
a lot of performance spark plugs have the screw on caps so they can be used with either types of plug wire ends- Top
- Top
a lot of off road vehicles like dirt bikes,quads and snowmobiles use the plug with just the threaded part showing and you have to remove the screw on cap.- Top
so which do I order neither says they're recommended for my car..but I know a lot of people run them and like them.- Top
Brandon,
Have you tried a local parts store like NAPA or even Auto Zon e, Pep Boys or others?
Most carry many types and brands of plugs. I get AC, Autolite and others for about $2.50 each.- Top
Do you need 100? In my crap
Attached FilesDick Whittington- Top
