I know I have the right length wires on the right cylinder, no question there.
on the passenger side I have cylinder wire lugs for cylinder 2 & 4 on the first valve cover bolt from the front and it reaches but is tight.
I have cylidner wire ground lugs for cylinder 6 & 8 on the 3rd bolt and they look fine.
on the driver side, cylinder wire ground lugs for cylinder 1 & 3 the #3 cylinder wire won't reach the first valve cover bolt from the front so I put them under the 2nd valve cover bolt from the front is this correct???????
then I put cylinder wire ground lugs for cylinder 5 & 7 under the rear/last valve cover bolt..
is this correct or no the aim is a hunk of junk on this one and I see pictures that vary from car to car..what is correct?
this is on my 68 l36, thanks
