These are the symbols that appear on my engine pad for an assembly date. In looking at the 67 judging manual, these do not appear to be correct or am I just not interpreting them correctly? The "V" and "HT" are correct but what about the middle symbols. Also, I checked the casting number and it is correct but casting date appears to be incorrect for the car build date. The build date for the car is 11/18/1966 but the casting date appears to be "K96" which if I am reading the manual correctly is 11/9/1966, only 9 days before assembly. The other item I notice is the carb. There is a part number stamped into the horn of the carb which appears correct as does the "list" number which is directly below the part number. However, below the "list" number there "3255" which does not correspond with what the judging manual says, there is no 3 character code. Sorry to be so wordy but if anyone could help I would appreciate it, since everyone has been helpful in the past. Thanks, Dennis
