Installed New Door Panels And Window Crank Spacers. Now I Cant Get The Window Crank On Far Enough To Engage Gear. Please Help. Thanks.roger 51103
1970 DOOR pANELS
Re: 1970 DOOR pANELS
Bob, are the window crank spacers exact thickeness as the ones you took off ? are the door panel secure to the door with upper and lower fastners ? Are the cut outs on panel for the window cranks the same dia. as the factory door panels, are the tangs on spacers bent over to secure to the panel?New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
This is a common problem -- reproduction door panels don't fit the curvature of the door, and the result is the door hardware doesn't fit or doesn't fit well. I have seen some solutions suggested here, but I will let those with experience speak to them. What is the door panel backing material on your replacement door panels?Terry- Top
Not only do they not fit the contour, they are much too thick. 30 years of complaining to the suppliers has had some good results wouldn't you say?This is a common problem -- reproduction door panels don't fit the curvature of the door, and the result is the door hardware doesn't fit or doesn't fit well. I have seen some solutions suggested here, but I will let those with experience speak to them. What is the door panel backing material on your replacement door panels?- Top
