1970 DOOR pANELS - NCRS Discussion Boards
1970 DOOR pANELS
  • Roger M.
    • December 9, 2009
    • 2
    1970 DOOR pANELS
    Installed New Door Panels And Window Crank Spacers. Now I Cant Get The Window Crank On Far Enough To Engage Gear. Please Help. Thanks.roger 51103
    • 6940
    Re: 1970 DOOR pANELS
    Bob, are the window crank spacers exact thickeness as the ones you took off ? are the door panel secure to the door with upper and lower fastners ? Are the cut outs on panel for the window cranks the same dia. as the factory door panels, are the tangs on spacers bent over to secure to the panel?
    • Sal C.
      • December 1, 1984
      • 430
      One thing you can count on with reproduction interior parts for a 1968 through 1975 Corvette is that they will fit like crap.
        • 15573
        This is a common problem -- reproduction door panels don't fit the curvature of the door, and the result is the door hardware doesn't fit or doesn't fit well. I have seen some solutions suggested here, but I will let those with experience speak to them. What is the door panel backing material on your replacement door panels?
        • Wayne W.
          • April 30, 1982
          • 3605
          Not only do they not fit the contour, they are much too thick. 30 years of complaining to the suppliers has had some good results wouldn't you say?
