I'm trying to remove the end bolts on the rear spring on the orange 72. I've got the cotter pins removed (well, broken off so they're not a problem) and there is no way that the castle nut at the bottom of that long bolt will move. I let it sit with PB blaster on it for 48 hours, but it won't budge. Right now I'm using a box end wrench on the top end of it in the trailing arm and a 1/2 in breaker bar on a socket on the lower end.
Other than cutting the bolt (not easy) are there any other tricks to remove that nut from this bolt?
Patrick
Patrick
