55 corvette brake pedal stop - NCRS Discussion Boards
  • Al M.
    • February 1, 2004
    • 64
    My brake pedal uses the brake light switch bracket as it's stop which I think is correct. Over time and use, the stop has been tapped back to a point where the piston came out of the master cylinder. Is this just a matter of making sure those bolts are real tight or am I missing something here. Was there ever a rubber stop on the bracket to cushion the return? Haven't seen one in any diagrams or parts books and the metal on metal doesn't seem right.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 55 corvette brake pedal stop
    Brake switch dont stop the pedal MS piston has a locking ring , you better remove the MS and see wonts going on , it has a snap ring to keep the shaft IN!
    • Al M.
      • February 1, 2004
      • 64
      yep. It was missing. Thanks.
