66 shoulder harness ?? - NCRS Discussion Boards
  • Bill H.
    • November 15, 2007
    • 54
    still restoring a 66 bb that previous owner described to be a sholder belt car. it came with a set of shoulder belts and seat belts, but how to be sure? there holes in the body near the wheel wells and a hole on each side of the chassis. (the holes are not in the same spot and they are on the top of the rail) they look to be tapped.
    is there a mounting plate, angle plate that would attach?
    any pics of the chassis mount area would help
    the am dosent indicate anything, but a bolt into the chassis (i think)
    please advise if i have a seatbelt car ( early jan 66)
    thanks
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 66 shoulder harness ??
    Bill - Before you get too far, do the tags on the seat belts and shoulder harness belts have the appropriate model numbers and dates for your car. While I realize that the tags can be reproduced, I'd start there because if the belts and associated information on the tags don't appear to be original, I'd have questions about other aspects. Good luck. Pete
    • Bill H.
      • November 15, 2007
      • 54
      great idea
      the belts i have are rough. in fact the seat belts are aircraft style and can't be opened. I cant find any #'s on them
      the shoulder harness is also aircraft style, darker blue straps and buckles
      info is:
      PONTONIER
      300-1
      PAT NO. 2896284
      3 01
      SECOND HARNESS
      PONTONIER
      300-1
      PAT NO. 2896284
      ??? 12
      MY CAR WAS BORN 01-04-66 bright blue interior
      any ideas would help
      also pic's of chasiss connection still needed
        Bill -
        There isn't any connection or anchorage to the chassis (unless it's a big-tank car). The anchor end of the shoulder belts uses a bolt that goes through a hole in the fiberglass underbody into a weld nut on a steel reinforcement that's riveted to the outside of the underbody. See photos below (from Paul LaTour, I think).
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1464
          Sorry, Bill, to be the one, but,
          Interior Section, of the '66 Manual, page 37 states that the Harnesses were introduced into production at approximately VIN 15,000.
          The buckles were of the second design Hamill push button style. (Page 34)
          HaND
          • Bill H.
            • November 15, 2007
            • 54
            John thanks for the photos
            guess i shouldn't believe past info. Mine looks nothing like that
            no indicataion of any plates, just a hole in body with a tapped hole in chasiss top rail below them. maybe after thought by past owner.
            It just saves a little $ toward something else.
            • Wayne M.
              • March 1, 1980
              • 6414
              Originally posted by Mike Murray (25129)
              .... Interior Section, of the '66 Manual, page 37 states that the Harnesses were introduced into production at approximately VIN 15,000. .....
              Mike -- I only have AIM UPC A85 sheet A3 (ie. no '66 TIM&JG) and I see that for tankers, the drawing was made 5-18-66 and released 2 days later. Does this imply that the first N03 shoulder belt cars [however few] would be typically VIN 22000 or later ?
