What is the number on the top of the crossmember for 4 speed trans. in '58? (RPO-685) Pg. 81 in Judging Guide says 686 for 4-speed...
Grease pencil mark on top of crossmember '58
Re: Grease pencil mark on top of crossmember '58
Marvin,
I wasn't certain whether you had a number and was asking about it or if you want to put a number there and were asking what number to put there. If you have a number, I'd be interested in knowing what yours is.
As far as I know, it is the RPO number for your transmission. It is certainly not the body sequence number that shows on the firewall and several other spots.
BTW, maybe you use "grease pencil" in a generic sense, but these markings are with a paint stick.
Bob- Top
I did a 59 in 1987, it had '19' on the center of the frame cross member, was a powerglide car. Also had a '25' on dash under the pad. Doubt the '19' had anything to do with the transmission configuration.
Dan
1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
