Grease pencil mark on top of crossmember '58 - NCRS Discussion Boards
  • Marvin C.
    • September 24, 2008
    • 29
    What is the number on the top of the crossmember for 4 speed trans. in '58? (RPO-685) Pg. 81 in Judging Guide says 686 for 4-speed...
  • Ted S.
    • January 1, 1998
    • 747
    Re: Grease pencil mark on top of crossmember '58
    What marking does it have? Are you sure it not the production number?
    • Bob B.
      • March 1, 2003
      • 831
      Marvin,
      I wasn't certain whether you had a number and was asking about it or if you want to put a number there and were asking what number to put there. If you have a number, I'd be interested in knowing what yours is.
      As far as I know, it is the RPO number for your transmission. It is certainly not the body sequence number that shows on the firewall and several other spots.
      BTW, maybe you use "grease pencil" in a generic sense, but these markings are with a paint stick.
      Bob
      • Dan H.
        • July 31, 1977
        • 1365
        I did a 59 in 1987, it had '19' on the center of the frame cross member, was a powerglide car. Also had a '25' on dash under the pad. Doubt the '19' had anything to do with the transmission configuration.
        Dan
        1964 Red FI Coupe, DUNTOV '09
        • Marvin C.
          • 29
          I want to know what number I put on the top of the crossmember, for a 4-speed, with my paint stick, 686 or 685? I thought it should be 685, but the judges manual says 686?
          • Dan H.
            • July 31, 1977
            • 1365
            Marvin, maybe none of the above?
