A. O. Smith door?
Re: A. O. Smith door?
Joe 63 doors used the large flat head rivets, not the pop rivets SOOO the door could be a 63. Phil 8063The photo shows a Corvette door with 2 flat head and 2 pop rivets under the dogleg weatherstrip.
If all St.Louis Corvette doors used 4 pop and no flat head rivets under the dogleg weatherstrip,
and all 1963 Corvettes had bodies manufactured in Missouri,
then the door pictured in the photo could not be a 1963 Corvette door.- Top
THAT IS INTERESTING!!!!!!!!
Why would that be that so, I wonder?
It calls into question how this statement could have been made in post #9:
If that door was covered in primer, would Wayne have been able to make the determination?- Top
I have an AO Smith 65 coupe. The door guts are green but the access panels on both doors are black and were never at any time green.
Jim- Top
Phylip, Yes, some, maybe all 63 doors used the large head rivets. I dont know when the change occured. So, you are technically correct on that account. But, it would have to be a later `63, as it has the later style auxiliary dog leg w/s. When it comes to rivet usage, it has always interested me why they used what they did. Those rivets were right there and used for other things. Why did they change their construction method, and was it totally inclusive? I dont know, but it tends to hold for 64 and later at least that St. Louis bodies had pop rivets in that location.
63 Door, ~ serial # 500
Typical AOS
Typical St. Louis
- Top
Nice Pics Wayne. Can you explain this pic.
Notice the weatherstrip! Hint Hint!
JRAttached Files- Top
Phil,
The door pictured in the first photo could not have been a 1963 door from the rivet aspect. Look at Joe Ray's photo in post #21 and you'll notice that the 1963 door uses flat head rivets in ALL 4 locations adjacent to the dogleg weatherstrip, not simply the middle 2, as was used with later AO Smith doors. Of course, St.Louis doors use pop rivets at all 4 locations adjacent to the dogleg weatherstrip. So, there are three configuration options here, not 2. Only one question remains: are "late" production '63 doors different in the rivet configuration from early 1963 doors?.
Further, the door pictured in the first photo could not be a 1963 door by virtue of its gray composite.- Top
These large rivets can be changed with 1/4-20 weld studs with flat heads. The weld studs look like rivets.
