The following my also apply for Corvettes:
John: I have a 69 Z28 that got certified by your friend Jerry McNeisch.
He tells me my Voltage Regulator and Horn Relay worked OK but where
"Generic". I presume the correct V/R is 1119515 and H/R is 1115890. Those numbers match your 69 Z28 correct? I'm told the H/R has no dates
on it but the V/R does. I found one V/R with 7L on it which I presume is
Dec. of 1967. I know this is probably too early for a 06A 69 Camaro but have
you found them that old with your findings at Camaro.Org? We all know
that some parts lay around in the bin a long time before use. Comments
from all are welcome.
Larry
Larry
