Happy New Year Everyone,
I have waited a good part of the year for this week knowing that I would have some time to do a few odds & ends on the Vette. One thing that I wanted to tackle is a hesitation/stumble upon acceleration from a stop when the car is cold. Sometimes the engine will also bog/surge in second gear as well. Once the engine is warmed up, the issues disappear and the car runs great. I searched the archives and the Internet and determined that my problem is the electric choke on my Edelbrock carburetor. Well, I am now frustrated to the point of wanting to "choke" the carburetor
. I first tried adjusting the choke by turning the black cover to the right to keep the choke closed longer, but after eventually turning it all the way to the right, discovered that the choke wasn't working at all. It is wired directly to the fuse block into a spade accessory slot, so I checked to make sure I was getting 12 volts. Much to my surprise, it wasn't getting any power. So I changed it to another slot which, when the key is turned on, provides 12 volts at the block and at the choke. YES... not
. Well then, it must be a bad choke, right? Luckily, I found a local performance auto parts store that stocks Edelbrock parts and purchased a new choke (not including the linkage piston housing). Cheap enough, and I assumed it would solve the problem... but I am still having the same issue. What the
?? Anyone have an answer to this puzzle? Do I need a new linkage piston housing? When I turn the black cover/dial from one extreme to the other (lean to rich) with the engine off, the choke valve/blade hardly moves at all. Without the choke and a higher "fast" idle, my car will continue to stumble off the line
. Help save my sanity!!
Thank you,
Roger (50141)
. Help save my sanity!!Thank you,
Roger (50141)
