Re: Edelbrock Electric Choke Issue
from the looks of the pictures you must not have any exhaust heat to the intake cross over because the paint is not burned off of the manifold where the heat riser crossover is located. i wonder if the heads do not have a heat riser crossover opening in them. looking in a GM performance part catalog it looks like most all corvette aluminum heads have no heat riser crossover passage because they were designed to work with electronic fuel injection and if this is the case you may be stuck with this problem till the engine reaches full operating temp.
