This past week end I performed the Hinkley/Williams (or W/H) valve adjustment on my original 63 L-76. I set them at a cold .008" (I) and .016" (E). my first impression, as I went through the procedure was that my intakes were about right from my previous adjustment (about 6 mos/ago), but all the exhausts had been about .002" loose. I went through them twice. After having applied a timing tape to the balancer, I barred the engine over using a torque wrench with a ratchet head and 5/8" socket on the center bolt of the balancer. From the onset, I found the center bolt to be loose (untorqued), so it took no more than 40 ft lbs. to turn the engine in the normal direction of rotation (CW from the engine front, CCW from the driver seat). Conditions were that the plugs were still in place, battery disconnected and car up on ramps - none of which probably mattered.
Upon my first road test, I noticed that my low end performance had suffered some, where as, the overall road performance showed noticable improvement. It pulls stronger in the mid to upper RPM range in all gears. It had always had good torque in 4th gear at normal cruising speeds, but the sense now is that it is unnecessary to downshift.
All in all, I'd say the change has awakened the beast. The difference is quite noticable and I strongly recommend it to any one with an SHP equipped Vette.
Special thanks to both John Hinkley and Duke Williams for their efforts to develope and document this procedure. I only wish it had been done 55 years ago. It would have saved me a lot of oil burned hands and severe head aches, to say nothing about the improvement my ET slips would have shown.
Stu Fox
Stu Fox
