Re: L-76 Engine Performance w/H & W Valve Adj.
Got to drive today and didn't get far before I noticed a pretty loud clacking from the valves. I got back to the garage, pulled the valve covers and started checking all of the lash settings. Got to the 4I valve and saw the rocker nut had lossened by several turns. The threads on the stud and the nut look fine, so I'm guessing they have worn just enough that they need to be replaced.
Does that solution make sense?
Also, just doing a sanity check, when I am looking at the cylinders, I am assuming the exhaust valve is on the left and intake on the right, is that correct?
Thanks for any suggestions
