I am in the process of restoring my 66 hubcaps and have a part that only showed up on 1 out of my 4 hubcaps. Per the attached picture, one of my hubcaps has an extra thim metal solid disc that was riveted on behind the plastic flag emblem (upper right). All of the original rivets look intact on the other hubcaps so not sure if they fell off at some point or if they were ever there. I searched all of the corvette houses and none show this as a replacement part. So I have a couple questions. 1) was this "cap" installed on all hubcap spinners? 2) If yes, does anyone know a source to find them? 3) If no source, would there be a judging hit if I reassembled without them? Thanks - Joe
66 Hubcap part help
Re: 66 Hubcap part help
Joe,
Mine look much as yours do. I just cleaned them up as best I could with some fine steel wool and re-used them. I checked LIC and didn't see them listed separately and assume they might sell it as part of the spinner. Anyway, you might call them and ask if they sell it separately (or try calling Paragon).
Good luckRob
'66 327/300 Regional Top Flt
'08 6 speed coupe- Top
Thanks Ryan, upon closer inspection it looks like the 3 with the missing cap had the center emblems replaced at some point. It looks like they have been re-peened over. Probably wasnt enough meat on the rivet to install the new emblem and cover. Anyway, now off to search for an obscure set of hubcap inner caps....- Top
When my '66 was judged they did not remove the hubcap, so if it is on the back, it will not be judged.Big Tanks In the High Mountains of New Mexico- Top
