My 1963 Chevrolet Parts Catalog lists GM # 3825686 (in Gr. 5.803) as the steel wheel for the 63 Corvette & 63 Police car. According to Chevrolet Parts History the part number changes were follows:
"3825686 MIX 3834127 1-63"
"3834127 USE 3839814 10-63"
"3839814 USE 3838080 5-66"
I once owned the following used 1963 and 1964 Corvette wheels stamped "15 X 5 1/2 K" along with the following date codes: "1 63" (6 of them), "2 63", "1 64", "2 64", "5 64", "6 64" (or maybe "9 64"???), and believe or not "6 59" (stamping error???). I also one owned a NOS 3839814 wheel dated "3 65".
By the way, has anyone ever seen a 63-64 Corvette wheel dated "6 59"? I saw one at the Carlisle auto show many years ago so I know there are at least 2 of them in this world, stamping error I presume.
NOTE: the "15 X 5 1/2 K" wheel dated "6 59" was a 63-64 Corvette wheel, NOT a 1959 Corvette wheel.
My question is as follows: are the "early" 63 wheels (GM # 3825686) made in the Fall of 1962 EXACTLY THE SAME as the "late" 63 wheels (GM # 3834127) made starting approximately Jan. 1963? I ask this because of the term "MIX" used in the Chevrolet Parts History. I know that Joe Lucia knows something about the terms "MIX" and "USE" and I hope to get his comments.
All my former 3834127 wheels (dated from "1 63" to "5 64") had a 2.78" hub hole diameter. The 3839814 wheels (dated "6 64" or "9 64"??? and "3 65") had a 2.91" hub hole diameter (about 0.13" or about 1/8" larger) as well as a small hole about 1/8" in dia.in one of the "nubs" on the front face of the wheel. From what I understand the 3839814 wheel may have never been installed on the 1964 Corvette assembly line even though the 3839814 wheel appears in my 1964 Chevrolet Parts Catalog (effective Oct. 1963). I guess there were enough of the 3834127 wheels left over to use during the entire 1964 Corvette production. I guess if you bought a 1964 Corvette wheel "over the counter" during the 1964 production it would be the 3839814 wheel.
I also once owned a NOS 3838080 wheel which I believe to be original equipment on 1966 Chevrolet Police cars. The 3838080 rim profile is somewhat similar (but not exactly the same) as the rim profile on a 65-66 Corvette steel wheel (GM # 3869156) which can accommodate disc brakes.
